Acer Chromebook CB5-571-C5XU Speaker Replacement
Выберете то, что вам нужно
  1. Acer Chromebook CB5-571-C5XU Speaker Replacement, Bottom Case: шаг 1, изображение 1 из 2 Acer Chromebook CB5-571-C5XU Speaker Replacement, Bottom Case: шаг 1, изображение 2 из 2
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Speaker Replacement: шаг 2, изображение 1 из 2 Acer Chromebook CB5-571-C5XU Speaker Replacement: шаг 2, изображение 2 из 2
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Speaker Replacement, Battery: шаг 3, изображение 1 из 1
    • Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
    • Be careful not to lose the screw and have a small container nearby to place it in.
  4. Acer Chromebook CB5-571-C5XU Speaker Replacement: шаг 4, изображение 1 из 1
    • Using a plastic opening tool, disconnect the wires connecting the battery to the motherboard.
  5. Acer Chromebook CB5-571-C5XU Speaker Replacement: шаг 5, изображение 1 из 1
    • Gently lift the battery out and remove it from the laptop casing.
  6. Acer Chromebook CB5-571-C5XU Speaker Replacement, Speakers: шаг 6, изображение 1 из 2 Acer Chromebook CB5-571-C5XU Speaker Replacement, Speakers: шаг 6, изображение 2 из 2
    • Use the plastic pry tool to unlatch the two tabs on either side of the black ribbon.
    • Gently slide the black ribbon out from its socket and under the white ribbon.
  7. Acer Chromebook CB5-571-C5XU Speaker Replacement: шаг 7, изображение 1 из 1
    • Carefully remove the smaller black ribbon from the motherboard using the opening tool.
    • Be careful when prying the connector loose, its small size can make it difficult to grasp a corner of the connector.
  8. Acer Chromebook CB5-571-C5XU Speaker Replacement: шаг 8, изображение 1 из 1
    • Weave the black wire connecting the two speakers out of the small metal hooks.
    • It might be helpful to take a picture of how the wire is wrapped around the hooks, as this layout is important when the wire is put back.
  9. Acer Chromebook CB5-571-C5XU Speaker Replacement: шаг 9, изображение 1 из 1
    • Simply lift upwards on both speakers, and they will remove from their position.
Заключение
Еще один человек закончил это руководство.
️Gaetan Charles
Участник с: 10/26/17
119 Репутация
1 руководство автора
Команда
UMass Dartmouth, Team S6-G1, Rockett Fall 2017 Участник UMass Dartmouth, Team S6-G1, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G1
3 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 170
