Введение
The motherboard is the most important part of any computer, and it handles all the functions. However, if your computer is having one of these issues:
- Blue Screen of Death
- Freeze or Glitches all the time
- CPU Restart Abnormally
- PC overheats abnormally
- Abnormal Beeps Noises from PC
- Not Recognizing Hardware
you may want to consider replacing the motherboard. This guide will provide you with simple steps on how to replace the motherboard on an Acer Chromebook R11 is C738T-C44Z.
Выберете то, что вам нужно
Lay the laptop with the back side up.
Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
Unplug the battery connector from the motherboard. (The motherboard is a group of wires in rainbow colors)
Use a Phillips #1 screwdriver to remove the two 3 mm screws, (one on each side of the battery), that secure it in place.
Remove battery from its holder by pulling it upwards from the device
Attempt to remove it as gently as possible to avoid damaging the Motherboard
Install the new battery and again use a Phillips #1 screwdriver to remove the two 3 mm screws
Disconnect the two antenna cables (one black and one white) that are attached to the wireless card.
Use a Phillips #1 screwdriver to remove the single 3 mm screw that secures the wireless card.
Disconnect the LED board ribbon by pulling it out gently.
Disconnect the speaker cable.
Disconnect the daughterboard ribbon by flipping up the white tab and pulling it out from the motherboard.
Use a Phillips #1 screwdriver to remove the two 3 mm screws that hold the hinge down.
Use a Phillips #1 screwdriver to remove the three 3 mm screws that secure the motherboard.
Еще один человек закончил это руководство.
