Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement
Выберете то, что вам нужно
  1. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement, Bottom Panel: шаг 1, изображение 1 из 1
    • Using a Phillips screwdriver, remove all eleven 7.0 mm screws from the bottom of the Chromebook.
  2. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: шаг 2, изображение 1 из 1
    • Find the seam along the edge of the device.
    • Wedge a finger into the groove and separate the panel from the device. If necessary, use a spudger.
    • The panel will still be connected to the device by internal wiring, so pull it off with some caution. It is best to flip the panel to the side once the seam has been broken.
  3. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement, Battery: шаг 3, изображение 1 из 1
    • Remove the two 4.5 mm Phillips screws located at the sides of the battery.
  4. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: шаг 4, изображение 1 из 2 Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: шаг 4, изображение 2 из 2
    • Grip the battery connection using two plastic opening tools.
    • Carefully but firmly, pry the connector from its socket by pulling it towards the battery.
    • When reconnecting the battery to the motherboard, place the red wires closer to the edge of the device and the black wires towards the center.
  5. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: шаг 5, изображение 1 из 1
    • Lift the battery out by pulling upward.
  6. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement, Motherboard: шаг 6, изображение 1 из 2 Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement, Motherboard: шаг 6, изображение 2 из 2
    • Orient the laptop so the motherboard side is further away from you in a landscape position.
    • Use the flat end of the spudger to lift the the ZIF connector retaining flaps securing the three small ribbon cables.
  7. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: шаг 7, изображение 1 из 1
    • Pull out the locking mechanism of the touchpad ZIF connector with the narrow end of the spudger.
  8. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: шаг 8, изображение 1 из 3 Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: шаг 8, изображение 2 из 3 Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: шаг 8, изображение 3 из 3
    • Using tweezers, pull the five ribbon cables near the bottom of the motherboard from their sockets.
    • Using tweezers, pull the single cable near the top left of the motherboard from its socket.
  9. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: шаг 9, изображение 1 из 1
    • Remove the screen connector from the motherboard by pulling directly upward on the black tabs.
  10. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: шаг 10, изображение 1 из 1
    • Remove the 2.0 mm screw from the Wi-Fi card.
  11. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: шаг 11, изображение 1 из 1
    • Slide the Wi-Fi card out from the port with tweezers.
  12. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: шаг 12, изображение 1 из 1
    • Remove the two 4.5 mm screws and a 2.0 mm screw from the middle of the motherboard.
  13. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: шаг 13, изображение 1 из 2 Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: шаг 13, изображение 2 из 2
    • Unscrew the two 4.5 mm screws from the top right metal tab connected to the motherboard.
    • Lift the right corner upward to remove the metal tabs from the motherboard
  14. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: шаг 14, изображение 1 из 1
    • Lift the motherboard upward to completely remove it from the base.
Заключение
9 участников успешно повторили данное руководство.
Elizabeth Crisologo
Участник с: 04/26/17
278 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S23-G2, Livingston Spring 2017 Участник Cal Poly, Team S23-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G2
4 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 17
За всё время: 5,230
