Введение
This guide will help you successfully remove the microphone out of your Acer Chromebook Spin 15 CP315-1H-P1K8. If the microphone component for this laptop is not functioning, use this guide to properly remove the faulty microphone for replacing.
Выберете то, что вам нужно
Flip the computer over so that the back is facing up.
Remove the twelve 6mm Phillips #1 screws from the bottom of the laptop.
Remove the five 6mm Phillips #1 screws from the hinges on either side of the laptop.
Unplug the camera/microphone ribbon cable from the circuit board.
Remove the single 3mm Phillips #1 screw from the Intel core.
Unplug the cable from the circuit board.
Use the plastic opening tool, create a gap between the back and front of the display.
Lift the front out with your hands.
Remove the two 3 mm Phillips #1 black screws from the microphone at the top of the display cover.
Remove the microphone component from the rest of the computer by detaching the connected wire.
The camera component of the laptop is connected to the same wire, so remove this as well.
Remove the microphone and camera wire out from around the display screen.
Remove the ribbon cable at the bottom of the display screen to completely free the wire.
Carefully remove the adhesive tape and take out the ribbon cable.
