Введение
This card connects the motherboard to the SD card and USB connectors.
Выберете то, что вам нужно
Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
Insert a screwdriver or spudger under the hinge to get it started then rotate it open by hand as far as possible.
Flip up the latch on the cable going from the I/O board to the LED board.
Flip up the latch on the cable from the I/O board to the motherboard.
Grasp the ribbon cable by the blue plastic reinforcement and pull the cable straight out to the right.
