Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
There are a few reasons to remove the battery. It may not hold a charge and needs to be replaced or it may need to be removed to do other work on the computer. This easy to follow guide will show you how to safely remove the battery without damage to the connections.
Выберете то, что вам нужно
Power down the laptop prior to beginning.
Turn the laptop over with the battery closest to your body.
Insert the pointed end of a spudger into the battery release.
Slide the release gently all the way to the left.
Place your hands on each end of the battery.
Pull the battery towards your body to remove it.
2 участников успешно повторили данное руководство.
