Acer Ferarri 4000 Hard Drive Replacement
Выберете то, что вам нужно
  1. Acer Ferarri 4000 Hard Drive Replacement, Hard Drive: шаг 1, изображение 1 из 2 Acer Ferarri 4000 Hard Drive Replacement, Hard Drive: шаг 1, изображение 2 из 2
    • The Ferrari 4000 ships with a PATA hard drive, which you will have the full knowledge to replace time and time again once you're done.
    • It's so easy, even a caveman can do it.
    • I cannot endorse the previous point since all cavemen are extinct.
  2. Acer Ferarri 4000 Hard Drive Replacement, Opening Up the Laptop: шаг 2, изображение 1 из 3 Acer Ferarri 4000 Hard Drive Replacement, Opening Up the Laptop: шаг 2, изображение 2 из 3 Acer Ferarri 4000 Hard Drive Replacement, Opening Up the Laptop: шаг 2, изображение 3 из 3
    • Let's get started by removing these two Phillips #0 screws holding down the hard drive bay cover on the bottom of the computer near the 3 USB ports.
    • These screws do not come completely out - they are meant to stay attached to the cover so you don't lose them.
    • Lift the bay cover to expose the drive cover
  3. Acer Ferarri 4000 Hard Drive Replacement, Protective Grille: шаг 3, изображение 1 из 3 Acer Ferarri 4000 Hard Drive Replacement, Protective Grille: шаг 3, изображение 2 из 3 Acer Ferarri 4000 Hard Drive Replacement, Protective Grille: шаг 3, изображение 3 из 3
    • The only thing separating you from the hard drive glory is a drive cover that looks oddly like a sports car grille...
    • Remove the 4 Phillips #0 screws.
    • Do not lift the cover just yet: there are two more screws securing it to the computer. If you lift it now, you risk bending the metal and damaging the cover.
    • Pull the tab to free the grille from the drive.
  4. Acer Ferarri 4000 Hard Drive Replacement, Removal: шаг 4, изображение 1 из 3 Acer Ferarri 4000 Hard Drive Replacement, Removal: шаг 4, изображение 2 из 3 Acer Ferarri 4000 Hard Drive Replacement, Removal: шаг 4, изображение 3 из 3
    • Pull back with a spudger (or your fingernails) where the drive plugs in to the computer.
    • Put your fingers where the red circles are and swing the drive up. Once it's up an adequate amount, grab it by its sides and pull it out of the computer.
  5. Acer Ferarri 4000 Hard Drive Replacement, You're finished!: шаг 5, изображение 1 из 1
    • You're done with the removal! Follow these instructions in reverse to install the new drive.
Заключение
5 участников успешно повторили данное руководство.
Nathanael
Участник с: 02/03/14
953 Репутация
Автор 2 руководств
Команда
Beautiful Savior Lutheran Church Участник Beautiful Savior Lutheran Church
Business
1 член
Автор 3 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 11
За всё время: 2,819
