Введение
Replace the motherboard in a Acer Iconia A1-810.
Выберете то, что вам нужно
Remove the back cover by lifting with a plastic opening tool, below the camera button slot.
Pinch the sides of the white resistor to safely remove it without damaging it or yourself.
Use a Phillips #000 screwdriver to remove the screws around the perimeter of the motherboard.
Disconnect the resistor attached to the orange tab by sliding the tail out.
Pry open the orange tab near the top left corner.
Continue to disconnect all resistors attached from the motherboard, using tweezers.
7 участников успешно повторили данное руководство.
8 Комментариев
Can you replace the mini USB charger port without replacing entire motherboard and losing data?
