Введение
Replace the screen of an Acer Iconia A1-810.
Выберете то, что вам нужно
Remove the back cover by lifting with a plastic opening tool, below the camera button slot.
Pinch the sides of the white resistor to safely remove it without damaging it or yourself.
Use a Phillips #000 screwdriver to remove the screws around the perimeter of the motherboard.
Disconnect the resistor attached to the orange tab by sliding the tail out.
Pry open the orange tab near the top left corner.
Continue to disconnect all resistors attached from the motherboard, using tweezers.
Wedge the Jimmy between the screen and body of the device and ease around the whole edge of the device.
While holding the side of the screen, press the metal plates behind the device to pop the screen out.
15 участников успешно повторили данное руководство.
Один комментарий
Before starting to remove the screen, remove the strip of black tape stuck over the screen ribbon cable (right hand end in the last picture) carefully lift the connector lock on the old screen connector and remove the ribbon cable completely.
Fit this ribbon cable to the new display before fitting the screen and the feed it through the slot provided as you install.
