Acer Iconia A100 Motherboard Replacement
Выберете то, что вам нужно
  1. Acer Iconia A100 Motherboard Replacement, Battery: шаг 1, изображение 1 из 1
    • Start at any side of the tablet.
    • Begin to take apart the tablet with a plastic opening tool along the sides of the tablet.
    • Work your way around the tablet.
    • There are four side pieces in total.
  2. Acer Iconia A100 Motherboard Replacement: шаг 2, изображение 1 из 1
    • Remove the five 4 mm screws from the edges of the tablet with a Phillips #00 screwdriver.
  3. Acer Iconia A100 Motherboard Replacement: шаг 3, изображение 1 из 1
    • Carefully separate the back piece from the device using a plastic opening tool.
    • Remember to open along the entire perimeter of the tablet.
  4. Acer Iconia A100 Motherboard Replacement: шаг 4, изображение 1 из 1
    • Turn the tablet over so that the battery is facing upwards.
    • Remove the four 4mm screws located around the battery.
  5. Acer Iconia A100 Motherboard Replacement: шаг 5, изображение 1 из 2 Acer Iconia A100 Motherboard Replacement: шаг 5, изображение 2 из 2
    • Use the tip of a plastic spudger or opening tool to gently push the connector head out of its socket.
    • Use your fingers or the flat edge of a plastic opening tool to lift the battery up and off of the device.
    • Be sure to not have any water around the device while removing the battery.
    • Be sure to be cautious while removing the battery and remove carefully; avoid ripping the wires attached to the battery.
  6. Acer Iconia A100 Motherboard Replacement, I/O Board: шаг 6, изображение 1 из 1
    • Gently peel off any tape securing the FPC to the main plate.
  7. Acer Iconia A100 Motherboard Replacement: шаг 7, изображение 1 из 3 Acer Iconia A100 Motherboard Replacement: шаг 7, изображение 2 из 3 Acer Iconia A100 Motherboard Replacement: шаг 7, изображение 3 из 3
    • Locate the two connectors at each end of the FPC.
    • Use the flat edge of a spudger tool or your fingernail to gently pry each connector straight upwards out of its socket, then remove the FPC cable from the unit.
    • While a metal spudger tool is shown here, it is best to use a plastic spudger / opening tool when possible, and only use a metal spudger as a last resort!
    • You should now see the yellow-colored strip on the metal base marking the location of the FPC
  8. Acer Iconia A100 Motherboard Replacement: шаг 8, изображение 1 из 1
    • Locate the L-shaped I/O Board.
    • Locate the gray 3G Antenna wire.
    • If the gray 3G Antenna wire is connected to your I/O Board, disconnect it. If for some reason the 3G Antenna wire is already disconnected from the I/O Board (as it was in this device) simply lift it out of the way.
  9. Acer Iconia A100 Motherboard Replacement: шаг 9, изображение 1 из 2 Acer Iconia A100 Motherboard Replacement: шаг 9, изображение 2 из 2
    • Locate the microphone cable.
    • You should be able to gently pull it out of its socket using only your fingers.
    • The spudger is used in the photo merely to hold up / identify the disconnected mic cable head.
  10. Acer Iconia A100 Motherboard Replacement: шаг 10, изображение 1 из 3 Acer Iconia A100 Motherboard Replacement: шаг 10, изображение 2 из 3 Acer Iconia A100 Motherboard Replacement: шаг 10, изображение 3 из 3
    • Locate the light sensor connector.
    • Use the tip of a spudger or your fingernail to lift up and flip the small retaining flap on the connector. The light sensor ribbon cable should now be free, so simply pull it out.
    • This is a ZIF (zero insertion force) connector, which requires no force to remove / plug in the connector.
    • Please make sure you lift up on the small retaining flap on the connector, not the connector itself!
    • Use a Phillips #00 screwdriver to unscrew the single 3.0mm Phillips screw next to the light sensor connector.
  11. Acer Iconia A100 Motherboard Replacement: шаг 11, изображение 1 из 2 Acer Iconia A100 Motherboard Replacement: шаг 11, изображение 2 из 2
    • Carefully lift the I/O Board off the device.
  12. Acer Iconia A100 Motherboard Replacement, Speakers: шаг 12, изображение 1 из 3 Acer Iconia A100 Motherboard Replacement, Speakers: шаг 12, изображение 2 из 3 Acer Iconia A100 Motherboard Replacement, Speakers: шаг 12, изображение 3 из 3
    • Locate the speakers module, which consists of 2 square black speakers connected by wires.
    • Locate the white and blue Home Key FFC ribbon cable between the speakers.
    • Use the tip of a spudger or opening tool to lift up and flip the small hinge on the connector. Then gently pull the FFC ribbon cable out its connector socket.
    • While a metal spudger tool is shown here and may be used, it is best to use a plastic spudger or opening tool when possible. It is easier to damage cables when using metal tools, so be extra cautious when using a metal spudger like the one shown here!
  13. Acer Iconia A100 Motherboard Replacement: шаг 13, изображение 1 из 2 Acer Iconia A100 Motherboard Replacement: шаг 13, изображение 2 из 2
    • Locate the speaker cable. Use your fingers to pinch each side of the black head of the speaker cable, and gently pull it out of its socket.
    • The metal spudger shown in the photo is used only to identify the speaker cable, not remove it.
    • If you're unable to get a good grip on the black connector head itself, gently pull from the wires near the connector head's base.
    • Be sure to pull on the wires near the base and evenly on the full width of the wires so no individual wire is over-strained, which may cause damage!
  14. Acer Iconia A100 Motherboard Replacement: шаг 14, изображение 1 из 2 Acer Iconia A100 Motherboard Replacement: шаг 14, изображение 2 из 2
    • Unscrew the 4mm Phillips screws securing the speakers module to the device using a Phillips #00 screwdriver.
    • There are two 4mm screws in total (one screw securing each speaker).
  15. Acer Iconia A100 Motherboard Replacement: шаг 15, изображение 1 из 2 Acer Iconia A100 Motherboard Replacement: шаг 15, изображение 2 из 2
    • Now both speakers should be free. Use the edge of a spudger tool to lift each speaker off the device, or use your hands to simultaneously lift each square black speaker off of the device.
    • If intact, the two speakers should be connected by wires, forming a one-piece speakers module.
  16. Acer Iconia A100 Motherboard Replacement, Motherboard: шаг 16, изображение 1 из 1
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the connector.
    • Use your fingers to gently pull the orange cable out of the connector socket.
    • This is a ZIF (zero insertion force) connector, which requires no force to remove or plug in the connector.
    • Please make sure you lift up on the black retaining flap on the connector, not the connector itself!
  17. Acer Iconia A100 Motherboard Replacement: шаг 17, изображение 1 из 1
    • Remove the six 3.0 mm screws securing the motherboard to the bezel using a Phillips #00 screwdriver.
  18. Acer Iconia A100 Motherboard Replacement: шаг 18, изображение 1 из 2 Acer Iconia A100 Motherboard Replacement: шаг 18, изображение 2 из 2
    • Lift the motherboard off the main plate.
Заключение
Bree Abernathy
Участник с: 03/01/17
341 Репутация
Автор 3 руководств
Команда
IUPUI, Team S1-G4, Harley Spring 2017 Участник IUPUI, Team S1-G4, Harley Spring 2017
IUPUI-HARLEY-S17S1G4
4 членов
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 8
За всё время: 408
