Введение
In this guide you will remove the rear cover in order to access internal components.
Выберете то, что вам нужно
Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
Slide the tool along until you have completely separated the rear cover.
If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
Once all the sides have been separated, you should be able to simply lift the cover off of the device.
2 участников успешно повторили данное руководство.
