Введение
The video is for fully disassemble the tablet, but you can follow the steps until the separating the LCD display.
Выберете то, что вам нужно
Видео обзор
Switch-off the tablet.
If you can't switch it off, use the reset button to do this.
With a cutter and a plastic tool remove the back cover.
First, disconnect the battery.
Now, disconnect the loudspeaker and remove the back cover.
Remove all scotch tapes and disconnect the touch screen flex cable...
LCD display flex cable,
the microphone,
and the WiFi and Bluetooth antennas flex cables.
The battery is glued to the LCD display metal shield with a double sided adhesive tape.
Use plastic tools and carefully remove it.
Remove all tapes from the LCD display metal shield.
The LCD display is held by metal frame and some locking clips on it.
Use a cutter and a plastic tool to separate the LCD.
Now, install the new LCD display and reassemble the tablet.
Did you do it successfully?
6 участников успешно повторили данное руководство.
