Введение
Follow this step-by-step guide to replace the motherboard for the Acer Iconia One 8 (B1-850). The motherboard contains the location where the major connections in the device come together. Before beginning, be sure to power off your device and remove it from any external source of power.
Выберете то, что вам нужно
Begin by opening the back panel.
Wedge a plastic opening tool in between the front and back shell and gently separate.
Disconnect the metal tabs connecting the battery to the motherboard frame.
Use tweezers to carefully remove the front camera from the adhesive on the motherboard.
Flip the device back over.
Remove the motherboard from the metallic frame by feeding the back camera and front camera cable through the port.
Remove the front camera from the device.
