Выберете то, что вам нужно
Power off the device
Remove any cables that might be connected to your device
Make sure the device is placed on a flat surface with the display screen facing up
Use your fingers to pull back and remove the yellow plastic tape covering the battery cable.
Use the flat side of the heavy duty spudger to lift the small black plastic flap.
Use the flat end of the spudger to pry the battery up from all edges, and remove it from the back panel.
6 участников успешно повторили данное руководство.
3 Комментариев
It looks like not too hard to fix it
Hello, what are white and yellow cables, could I somehow replace original battery with generic (2 wire lipo - cheaper one) . can those 2 wires be cut and could tablet work? thanks
Hello , can I replace this 4 wire battery with 2 wire generic one ? What are white and yellow cables , could they be removed or somehow reconnected for use of 2 wire (red and black) generic tablet battery. Thanks
