Выберете то, что вам нужно
Power off the device
Remove any cables that might be connected to your device
Make sure the device is placed on a flat surface with the display screen facing up
Use your fingers to pull back and remove the yellow plastic tape covering the battery cable.
Use the flat side of the heavy duty spudger to lift the small black plastic flap.
Use the flat end of the spudger to pry the battery up from all edges, and remove it from the back panel.
Use the pointy end of the spudger to remove the black tape holding the wires in place and completely free the wires.
