Введение
Replace the speaker in your Acer Iconia Tab 500.
Выберете то, что вам нужно
To start, gently separate one corner of the case using the black spudger.
Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
Locate the 4 screws and cable that hold in the two speakers.
Use the Phillips #1 screwdriver to remove these 2mm black screws.
Remove the 2mm silver screws.
Carefully remove the connector cable by pushing on the rim of black plastic insert.
Unfortunately, the top speaker is a wedged under the motherboard.
To get this speaker out, use the spudger and gently pry it out.
2 участников успешно повторили данное руководство.
