Введение
The USB-A/Micro-USB Port enhances the connectivity of the tablet to other portable devices. Follow this guide to replace the USB-A/Micro-USB Port.
Выберете то, что вам нужно
Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
Continue separating the back cover along the short side closest to the camera and around the device.
When separated enough, a little more than halfway around the device, the back cover will be easy to take off.
Инструмент, используемый на этом этапе:Tweezers$3.99
Use the angled tweezers to disconnect the white motherboard-battery connector in the middle of the side opposite the docking port.
Use the plastic opening tool to flip up the locking mechanism for the flat, white ribbon cable connecting to the USB ports' board.
Remove the flat, white ribbon cable.
Use a Phillips #1 screwdriver to remove the two 4.0 mm Philips screws attaching the metal plate, USB board, and device.
