Введение
If it says "Too many pattern attempts..." or not working Android system, or you want to erase all data.
__________Video tutorial:__________
Видео обзор
From the reset hole we can make reset without erasing data.
Power of the tablet. Push and hold Vol(+) and Power On keys together in the same time.
Now you are in the Boot Mode menu. With Vol(+), (-) go to [SD Update Image Mode] and select it with Power On key.
Now you are in Android System Recovery Menu. Choose "wipe data / factory reset", "Yes -- delete all user data". And finally "reboot system now".
11 участников успешно повторили данное руководство.
2 Комментариев
I have a problem when it came to SD image update mode I get the log acer restarts does not pass the second part you have any idea?
tengo un problema cuando entró a SD image update mode me sale el log de acer se reinicia no pasa a la segunda parte tienes alguna idea ?
