Введение
This guide will give you a step by step process for replacing the screen of an Acer Iconia W3-810 in the case of a screen failure. This guide can be used if the screen is cracked due to physical damage or burns out from excessive use.
Запчасти
Детали не указаны.
Place the tablet face down on a flat surface with the charger facing toward you.
Pull the ribbon cord by pushing the clamp on the port toward you with the plastic opening tool.
Use the plastic opening tool to carefully slide the power cord from its slot by pushing it out from both sides, then remove the cord from its port with your hand.
Pull on the ribbon cord carefully in order to break the seal between the ribbon cord and the battery. Do this until the cord is completely free of the battery.
Use the plastic opening tool to gently wedge out and lift the battery pack from the device.
Carefully break the bond between the inner tape and the battery using the plastic opening tool. The tape can be found in the middle and either side of the battery.
Disconnect the speaker cord from the motherboard by carefully prying it out with a plastic opening tool.
Loosen the retaining flap using a plastic opening tool, and then pull the ribbon cord from its slot.
Unscrew the 3mm phillips head screws along the motherboard using a HH0 screwdriver.
Lift the retaining flap of the ribbon cord connecting the screen circuit board to the motherboard using a plastic opening tool.
Then, remove the ribbon cord from its slot using a plastic opening tool.
Unscrew the 3mm phillips head screws from beneath the screen circuit board using the same HHO screwdriver.
Unscrew the 3mm phillips head screws connecting speaker and home button circuit board from main frame using the HHO screwdriver.
Unscrew left speaker from frame by moving the ribbon cord out of the way to access the 3mm phillips head screws.
Loosen speaker cord from main back frame by breaking the tape seal using a spudger.
Loosen the main back metal frame from the front casing using a plastic opening tool.
3 участников успешно повторили данное руководство.
