Введение
This guide covers replacement of the battery in the tablet portion of this laptop; there is another identical battery in the keyboard portion that will be covered by a separate guide.
Выберете то, что вам нужно
Carefully insert your metal pry tool between the back cover and the frame at an angle as shown.
Give the tool a twist to the left to start separating the clips.
Work your way to the corner, prying and twisting to pop the clips as you go.
Insert an opening pick to make sure the clips don't close down again as you round the corner and start working on the right side of the tablet.
Continue as before, prying and twisting to release the catches.
Back to the bottom side again, this little part by itself is a little finicky to get unclipped, just follow the same procedure as with the first one.
And finally the home stretch between the keyboard/power connector and the right hand guide pin, back to where you started.
Grasp the plug by the tabs on either side and pull it straight out from the connector.
Remove the tape on the right side of the battery securing it to the tray.
Using a flexible piece of plastic, slip it under the battery and use it to slice the first adhesive strip.
Leave it in place while slicing the remaining strips.
