Введение
Use this guide to replace the Speakers in the Acer Nitro 5 Acer Nitro 5 AN515-53-55G9. This laptop has two speakers that come installed into the device.
Выберете то, что вам нужно
Flip the laptop upside down so that the bottom is facing up.
Identify the RAM tray on the bottom of the laptop.
Use the Phillips #0 screwdriver to remove the 9mm screw in the bottom left corner of the RAM tray covering.
Remove the RAM tray cover by prying up with a spudger.
Identify the Hard Drive tray to the left side of the laptop.
Remove screw with a #0 Philips screwdriver.
Lift up the Slot covering using a spunger.
Use the Phillips #0 screwdriver to remove the 9mm screws holding the back cover in place.
Remove the screws from the hard drive and remove it from the device.
Carefully remove the back shell from the device working your way around all the edges.
Removing the back shell of the computer and it will look like this.
The battery for the device is located at the bottom middle of the laptop at this orientation.
Locate the connector of the battery to the motherboard.
Using your fingers, slide out the connector.
Once the battery is removed your device should look similar to this.
Locate the plug for the speakers located at the red circle.
Unplug the cable from the motherboard as shown.
Carefully unroute the cables starting from the main plug.
Pull up on the left speaker as shown here to remove the speaker from the device.
Continue unrouting the cable from the device and following it to the right speaker.
Locate the Right Speaker on the device.
Pull up on the speaker to remove from the device.
6 участников успешно повторили данное руководство.
