Введение
This guide will walk you through the process of replacing a dying or dead Wi-fi card in an Acer Nitro 5 AN515-53-55G9. If you have connectivity issues with your computer, they may be alleviated by installing a new Wi-fi card.
Выберете то, что вам нужно
Use the Phillips #0 screwdriver to remove the 9mm screw in the bottom left corner of the RAM tray covering.
Remove the RAM tray cover by prying it up with a plastic opening tool.
Remove the screw on the Hard Drive tray with a Phillips #0 screwdriver.
Lift up the tray covering using a plastic opening tool.
Use the Phillips #0 screwdriver to remove the fourteen 9mm screws holding the back cover in place.
Remove the hard drive (if applicable) from the slot prior to removing the back cover.
Carefully remove the back shell from the device by prying at the creases with a spudger around all the edges.
Using your fingers, disconnect the white and black cables connected to the left side of the Wi-fi card.
Еще один человек закончил это руководство.
Один комментарий
My hard drive got disconnected and I can't locate where is the place to connect it
