Введение
This guide shows you how to replace a broken or damaged front and back facing camera on your device. This replacement involves removing delicate ribbon connectors, which should be handled with great care.
Выберете то, что вам нужно
Make sure that the tablet is turned off and disconnected from any power source.
Disconnect the tablet from the keyboard attachment.
If you have a Micro SD card in the tablet, remove it now.
Remove the two 3.5 mm Phillips #0 screws on either side the keyboard connection.
Starting from a corner of the tablet, use the plastic opening tool to create a gap between the screen and the back covering.
Slowly maneuver the plastic opening tool along the perimeter of the tablet to pry the screen and back covering apart.
Separate the back covering from the screen.
Peel off all of the Polyimide tape (yellow tape).
Remove the metallic tape covering the keyboard connection.
Unscrew the two 3.5mm Phillips #0 screws and open the ZIF latch.
Gently remove the silver part covering the battery and set it aside.
Open the ZIF (Zero Insertion Force) connectors .
Gently remove the ribbon cables.
Remove the four 4mm screws at the corners of the motherboard with the Phillips#0 bit screw.
Use the plastic opening tool to separate the glue that holds the battery to the screen.
Remove the battery and set it aside.
Separate the adhesive cable from the underlying copper ribbon cable.
Gently pry off the camera from from tablet backing.
Remove the camera and set it aside.
Еще один человек закончил это руководство.
3 Комментариев
No screen
no power now
no rear camera was initial reason for calling horrid acer for customer service
I was worried camera was broken but discovered after black screen and not working touch screen and mouse, it was not the case:
Got Acer 10 Tablet with Keyboard S1002 12V2 repaired:
1) by removing tablet from keyboard
2)pressing the volume down into volume position and pressing power at same time 30 secs
3)reset menu comes on and screen loads as normal
4) restart device
(when there is a problem with this two in one tablet, the device thinks it's a tablet before a pc)
5) admin prompts given after a restart is done which took about 40 mins; restart and flourish
***after restarting the whole pc began to work including front and rear cameras which was the issue I had contacted acer support about in the first place!)
jenny -
