Введение
Replacement fix for broken WiFi connection if all other troubleshooting options have failed.
Выберете то, что вам нужно
Power off the device and make sure it is disconnected from any external devices.
Use a plastic opening tool to create a gap between the front and back casing of the device.
Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
Disconnect the black ribbon connection attached to the motherboard.
Remove the chip fully by pulling the plastic tab on the left out.
Еще один человек закончил это руководство.
