Введение
If when charging your Acer Predator 17 G9-791 it boots up and then shuts down or has screen issues such as freezing or a blue screen, then use this guide to replace the motherboard.
Выберете то, что вам нужно
The service panel can be located on the bottom of the device. It is shown here as the panel located in the middle of the device, going from the upper vents to the bottom of the device.
Loosen the two Phillips #0 screws.
Pull up slightly on the top of the panel to help fully separate the screws from the rest of the device.
Remove the nine 4.5 mm Phillips #0 screws from the panel.
Remove four 14 mm Phillips #0 screws.
Remove six 7 mm Phillips #0 screws.
Slide the "unlock" slider up located to the right of the service panel and pull the disc tray out.
Remove the two 4.5 mm Phillips #0 screws located underneath the removed optical drive.
Pry up on the edges of the bottom cover and lift the bottom case off of the device.
Remove the five 4.5 mm Phillips #0 screws located on the perimeter of the fans.
Unscrew the six Phillips #0 screws enough to loosen the assembly from the motherboard.
Turn the device around.
Use the black tab to disconnect the one connector on the bottom of the motherboard.
Pull the motherboard up and out of the device. You may need to open the lid slightly for the removal process.
