Введение
In order to replace any parts inside the Acer Spin 3 SP315-51-757C, you will have to remove the back panel first. This guide can be completed very quickly and easily, as you will only need to remove some screws with a Phillips #0 screwdriver and pull the panel off the laptop using a plastic opening tool.
Выберете то, что вам нужно
Using an opening tool, pry open the back panel, starting at the silver screen hinges.
2 участников успешно повторили данное руководство.
