Введение
When an Acer Spin 3 SP315-51-757C turns on, but the operating system does not start, there is usually a problem with the hard drive. You may also want to get a hard drive with more storage and use it to replace your old hard drive. This guide shows you how to properly unplug and remove your hard drive from your laptop. When installing a brand new hard drive, be sure to have Windows installed onto the hard drive before putting it in your laptop.
Выберете то, что вам нужно
Using an opening tool, pry open the back panel, starting at the silver screen hinges.
Gently lift the closer side of the hard drive out of its slot.
Make sure not to pull too hard on the cables plugged into the motherboard.
Remove each rubber edge from the hard drive, and reassemble with a new hard drive.
2 участников успешно повторили данное руководство.
2 Комментариев
Awesome. Thanks for the tips here. Do you have any recommendations on what SSD may go with Acer Spin 3 SP315-51-757C ? I am a little clue less here since i am new to this, and any feedback here would help. Thanks.
I just replaced my HDD with a 1TB Crucial MX500 SSD. It was easy to clone the drive and simple to install. My computer went from almost unusable to better than new, I highly recommend it.
