Введение
If your Acer Spin 3 SP315-51-757C’s sound system is not muted and you do not hear any sound or hear distorted audio coming from your laptop, you may need to replace your laptops speakers. This guide will show you how to remove and replace both the left and right speakers using a Phillips #0 head screwdriver.
Выберете то, что вам нужно
Using an opening tool, pry open the back panel, starting at the silver screen hinges.
Remove the Phillips #0 screws from each speaker.
After unscrewing the right-side speaker, you will notice that its corner is used to secure a couple cables. You will need to remove these in order to remove the speaker.
Lift up the fan as lightly as possible to remove the speaker's wires underneath.
Carefully maneuver the wires from under the fan and remove each speaker from the case.
