Введение
Motherboard is the main printed circuit board, it holds, and allows, communication between many of the crucial electronic components of a system, such as the central processing unit and memory, and provides connectors for other peripherals, interface cards, and daughtercards: sound cards, video cards, network cards, hard drives, or other forms of persistent storage; TV tuner cards, cards providing extra USB or FireWire slots and a variety of other custom components. If in any case you want to replace your Acer Spin5 laptop’s motherboard, follow the instructions of this guide.
Выберете то, что вам нужно
Use the Phillips #1 screwdriver to remove six 6 mm screws.
Use the same screwdriver to remove six 5mm screws.
Use two opening tools to disconnect the cooling fan from the motherboard.
Remove the fan from the device.
Remove all peripherals connecting to the motherboard.
Remove the second chip.
Remove the wireless LAN chip.
Take off the connecting port with black tape.
Take off the last port with purple tape.
2 Комментариев
I need the motherboard where I can buy it..
I need the motherboard where I can buy it please...
