Введение
This technical guide provides a step-by-step process for replacing the screen assembly of an Acer Spin 5 N17W2 laptop. The Acer Spin 5 N17W2 is a popular convertible laptop that features a touchscreen display, making it a great device for both productivity and entertainment. However, if the screen becomes damaged or stops working, it can be a frustrating issue to deal with. With this guide, you'll be able to replace the screen yourself, saving you time and money compared to taking it to a repair shop. The guide includes detailed instructions, helpful tips, and recommended tools to ensure a successful screen replacement.
Выберете то, что вам нужно
Use the Phillips #1 screwdriver to remove the six 6mm screws.
Use Phillips #1 screwdriver to remove six 5mm screws.
Use the Phillips #1 screwdriver to remove the three 5mm screws.
Use the Phillips #1 screwdriver to remove the three 5mm screws on another side of hinge.
3 участников успешно повторили данное руководство.
