Введение
The trackpad is the component that tracks all user finger movement on a laptop. If your laptop is not properly tracking the movements of your cursor, the trackpad may need to be replaced. Follow these instructions to remove and replace the trackpad in your device.
Выберете то, что вам нужно
Remove the twelve screws on the back cover using the Phillips #1 screwdriver.
Remove two 4 mm screws at the two corners of the battery using the Phillips #1 screwdriver.
Using the blue spudger, pry the two black clips from the two ribbon cables on the bottom of the mouse pad.
Remove ribbon cables connected to the middle of the mouse pad.
Remove the adhesive tape from the left side of the mouse pad.
Using your thumbs, push the mouse pad from the inside of the computer towards ur self and slide the mousepad out of the computer.
