Введение
The motherboard holds together many of the crucial components of your computer. If your motherboard is failing your computer will display an error code with a series of audible beeps. It will also display the “Blue Screen of Death” representing it has failed.
Motherboard: Definition. A motherboard is one of the most essential parts of a computer system. It holds together many of the crucial components of a computer, including the central processing unit (CPU), memory and connectors for input and output devices.
Common symptoms of motherboard issues are similar to CPU problems: The system does not display anything; an error code appears; one or more beeps occur; the system locks; the system reboots; a Windows BSOD (blue screen of death) appears; or one or more of the ports, expansion slots, or memory modules fails.
Выберете то, что вам нужно
Flip your laptop over so that the model sticker is facing upward towards the ceiling.
Use a Phillips #1 screwdriver to remove the thirteen 6.5mm screws that secure the back cover.
Use a plastic opening tool to gently separate the back cover from the laptop. A snapping sound will be heard as a signal that the clips are being disengaged.
Use a Phillips #1 screwdriver to remove two 4 mm screws that secure the battery.
Use your hand to carefully pull out the wiring harness from its port that is located between the battery and the motherboard.
Remove the battery from the case.
Grasp the CMOS battery with the tweezers and remove it from the motherboard.
Using a Phillips #1 screwdriver, remove the one 4mm screw that secures the Solid State Drive.
Use your hand to pull out the Solid State Drive from the motherboard.
You will be pulling the solid state drive out to the left, as it will be connected to the port on the motherboard on its right side. This is opposite the direction that the pictures depict it.
Use Phillips #1 screwdriver to remove the two 4mm screws that are securing the fan.
Using your hand, pull out wiring harness to disconnect the fan from the motherboard.
Lift the fan out of the case to remove it.
Use the tweezers to disconnect the wiring harness in the bottom right corner of your laptop.
Using the tweezers, flip the white lock tab of the ZIF connector upward.
Pull the blue "MB High-Tek" ribbon cable out.
Using the tweezers, flip up the black lock tab of the ZIF connector upward.
Pull out the MB purple ribbon cable out.
Using the tweezers, flip up the black lock from the connector holding the display cable.
Remove the display connection wire from its port.
Using Phillips #1 screwdriver, remove the 4mm screw that secure the WiFi card.
Remove WiFi card from its port.
Using Philips #1 screwdriver remove the seven 4mm screws that secure the motherboard to the laptop.
Remove the motherboard by lifting it out from the back case.
Один комментарий
I was wondering if the CPU is soldered to the motherboard? Is it possible to remove the CPU and replace it with an upgraded CPU?
