Введение
If your Acer TravelMate P653-V-6882’s keyboard is still not responding after restarting the device and/or updating the keyboard drivers, then your keyboard may need to be replaced or reconnected.
Here is the guide on how to replace the TravelMate’s keyboard.
Выберете то, что вам нужно
Turn the computer over so the base is facing up.
Slide the battery lock to unlock position.
Flip the laptop so that the underside is now facing the bottom.
Open the LCD panel.
Use the flat end of a spudger to push in the six latches.
When the latches are pushed in, the keyboard will pop out.
Gently pry up the keyboard.
Slide the keyboard forward to access the keyboard cable.
Flip the connector latch up to open it.
Pull out the keyboard cable gently.
