Введение
Whether your Acer TravelMate P653-V-6882 begins to overheat, you need to access the I/O ports, or replace the LCD module, then you must remove the mainboard, also known as the motherboard.
Here is a guide on how to access the TravelMate’s mainboard (motherboard), where you then can begin to either remove it and fix any issues you are facing with the internals.
Выберете то, что вам нужно
Turn the computer over so the base is facing up.
Slide the battery lock to unlock position.
Pinch the two metal pieces holding the RAM sticks in place outwards.
Holding the sides of the RAM, slide the RAM sticks out.
Flip the laptop so that the underside is now facing the bottom.
Open the LCD panel.
Use the flat end of a spudger to push in the six latches.
When the latches are pushed in, the keyboard will pop out.
Gently pry up the keyboard.
Slide the keyboard forward to access the keyboard cable.
Flip the connector latch up to open it.
Pull out the keyboard cable gently.
Turn the computer over, open the LCD panel, and find the smart card cable connector.
Open the smart card cable connector latch.
Disconnect the cable.
Find the power button launch board cable connector.
Open the power button launch board cable connector latch.
Find the touchpad and fingerprint board cable connector.
Open the touchpad and fingerprint board cable connector’s latches.
Disconnect the cables.
Flip the laptop over so that the underside is facing up.
Remove the twelve 7mm Phillips #1 screws.
Remove the five 3mm Phillips #1 screws.
Disconnect the cables connecting to the WLAN module.
Open the LCD panel.
Locate the small gaps between the upper cover and lower case on the left and right side of the laptop.
Insert the opening tool into each gap to separate the one from the other.
Once the upper cover is separated, lift it from the lower case.
Detach the transparent tape securing the LCD cable.
Disconnect the LCD cable from the mainboard.
Detach the black tape covering the microphone cable.
Disconnect the microphone cable from the mainboard.
Lift the mainboard at an angle and gently turn it on its side.
Disconnect the LAN cable from the mainboard.
Еще один человек закончил это руководство.
