Введение
If your laptop is experiencing internal communication issues, use this guide to remove and replace your motherboard.
Выберете то, что вам нужно
Remove the thirteen 6mm Phillips screws using the #0 screwdriver.
Remove the back of the laptop.
Remove one 6mm Phillips screw from the Wi-Fi interface using the #0 screwdriver.
Remove the eight 7mm Phillips screws from the motherboard using the #0 screwdriver.
Еще один человек закончил это руководство.
