Введение
If your laptop's touchpad is unresponsive because of external damage, use this guide to remove and replace your touchpad.
Выберете то, что вам нужно
Remove the thirteen 6mm Phillips screws using the #0 screwdriver.
Remove the back of the laptop.
Remove one 6mm Phillips screw from the Wi-Fi interface using the #0 screwdriver.
Remove the eight 7mm Phillips screws from the motherboard using the #0 screwdriver.
Remove one 6mm Phillips screw from the middle of the touchpad with the #0 screwdriver.
Remove one 6mm screw from the corner of the touchpad frame with the #0 screwdriver.
