Введение
This is a step by step replacement guide for the bridge of an acoustic guitar. Replacing the bridge on a guitar may be necessary if the bridge is damaged or falling off. This is a fairly simple task and can be accomplished very easily by following this simple 10 step guide. No prior guitar repair experience or special tools are needed to accomplish this task. Just be careful, follow the steps, and it should turn out great!
Выберете то, что вам нужно
Remove the guitar strings.
Use a paper towel to remove any dust and debris from the neck of the guitar.
Carefully remove the bridge of the guitar with a putty knife or something with a thin dull blade.
Carefully remove any excess glue or debris on the body of the guitar from the old bridge.
Apply wood glue to the new bridge and attach it to where the old one used to be.
Еще один человек закончил это руководство.
Один комментарий
This is a good guide Mitchell. I would encourage anyone attempting this type of a job to go watch some of the videos on YouTube by Mr. Ted Woodford. He goes into great detail about the various pitfalls of removing bridges, they aren't always as simple. Personally I don't think this repair is something to be classified as 'easy' as well. Different guitars can have very very tough adhesive bonds. I had to remove a Taylor bridge once that was a bear to get off and ensure that it went back on cleanly. The bridge can also warp and deform once it comes free of the top, so it's a good idea to clamp the bridge to a known flat surface. I appreciate the steps you outlined here though.
