Adding images to an existing question
  1. Adding images to an existing question, Adding images to an existing question: шаг 1, изображение 1 из 3 Adding images to an existing question, Adding images to an existing question: шаг 1, изображение 2 из 3 Adding images to an existing question, Adding images to an existing question: шаг 1, изображение 3 из 3
    • Mouse-over Options on the top right corner of the Question field to reveal a dropdown menu.
    • Click on Edit to open the Edit Post page.
    • Before adding your image, position the cursor at the place in your text where you want to add the image. We suggest placing it at the end of the question.
    • Click on the image icon to open the Media Manager.
    • Click on Add Media and select files from your computer to upload.
    • Alternatively, you can simply drag and drop images into the Media Manager to upload them. If you did this, proceed directly to step 3.
  2. Adding images to an existing question: шаг 2, изображение 1 из 1
    • In the Add Media window, you can add images from the internet or your local machine.
    • To add images from your computer:
    • Click on the browse for files to find photos on your computer, or simply drag and drop them onto the window.
    • To add images from the internet:
    • Get the link to your desired image. You can usually do this by right-clicking the image and selecting Copy link address.
    • Paste the link into the field provided.
    • Click Grab Media to add the image to your Media Manager.
  3. Adding images to an existing question: шаг 3, изображение 1 из 2 Adding images to an existing question: шаг 3, изображение 2 из 2
    • Once the image is in your Media Manager, click on it to insert into your question.
    • The image should appear in-line at the spot where your cursor was positioned when you opened the Media Manager.
    • iFixit images show up in 4:3 format. Most modern cameras capture in 3:2 or 16:9, which will require a crop. If you change your capturing preferences when taking pictures to 4:3, you won't need to crop them in the Media Manager.
  4. Adding images to an existing question: шаг 4, изображение 1 из 2 Adding images to an existing question: шаг 4, изображение 2 из 2
    • After inserting the image, scroll to the bottom of the page and click Preview Edit.
    • A preview will be automatically inserted below the fields for you to review.
    • If everything looks good, click Submit Edit. If not, scroll back up and adjust your question as necessary.
Заключение
The image size for insertion must be 800 x 600 pixels otherwise there will be an error message in the Media Manager. It looks complicated, but is actually straightforward.
98 участников успешно повторили данное руководство.
oldturkey03
Участник с: 09/29/10
781 480 Репутация
Автор 119 руководств
Команда
Global Fixers Участник Global Fixers
Community
32 членов
Автор 531 руководств
2 Комментариев
I can believe, but must, that iFixit has made uploading images this difficult rather than they way it used to be done! What a bunch of putzes.
mayer - Ответить
Thanks to contributors. I was shocked when I had to look up how to do this.
Shelley - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 67
За последние 7 дней: 438
За последние 30 дней: 1,787
За всё время: 694,343
