Введение
This guide will show you how to adjust the height of the handle bars and align the stem with the front wheel.
Запчасти
Никакие детали не требуются.
  1. Remove the bolt cover with a flathead screwdriver. Remove the bolt cover with a flathead screwdriver.
    • Remove the bolt cover with a flathead screwdriver.
  2. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  3. Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench. After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side. If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
    • Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench.
    • After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side.
    • If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
    • Position the handlebars to your preferred height. Make sure not to pull cable and housing to tight. I could adversely effect shifting and braking performance.
    • Make sure you don't raise quill stem above minimum insert line.
  4. Align the direction of the goose-neck (adjustable quill stem) with the front tire. Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench. Pop the bolt cover back on.
    • Align the direction of the goose-neck (adjustable quill stem) with the front tire.
    • Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench.
    • Pop the bolt cover back on.
    • If calling a bicycle repair shop, refer to it as a adjustable quill stem (technical term) instead of goose-neck as mechanic may not know what you are talking about.
Финишная черта
aaron thielk
Участник с: 10.10.2010
1 726 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 5-13, Maness Fall 2010 Member of Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 членов
Автор 11 руководств
Один комментарий
Anyone know where/how to buy a replacement bolt cover?
Bennett Hart - Ответить
Просмотр статистики:
За 24 часа: 1
За 7 дней: 5
За 30 дней: 10
За всё время: 7,886
