Adjust Goose-neck (adjustable quill stem) on Specialized Expedition
Выберете то, что вам нужно
  1. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: шаг 1, изображение 1 из 2 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: шаг 1, изображение 2 из 2
    • Remove the bolt cover with a flathead screwdriver.
  2. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: шаг 2, изображение 1 из 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: шаг 2, изображение 2 из 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: шаг 2, изображение 3 из 3
    • Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench.
    • After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side.
    • If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
    • Position the handlebars to your preferred height. Make sure not to pull cable and housing to tight. I could adversely effect shifting and braking performance.
    • Make sure you don't raise quill stem above minimum insert line.
  3. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: шаг 3, изображение 1 из 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: шаг 3, изображение 2 из 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: шаг 3, изображение 3 из 3
    • Align the direction of the goose-neck (adjustable quill stem) with the front tire.
    • Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench.
    • Pop the bolt cover back on.
    • If calling a bicycle repair shop, refer to it as a adjustable quill stem (technical term) instead of goose-neck as mechanic may not know what you are talking about.
Финишная черта
Еще один человек закончил это руководство.
aaron thielk
Участник с: 10/10/10
1 882 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 5-13, Maness Fall 2010 Участник Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 членов
Автор 17 руководств
Один комментарий
Anyone know where/how to buy a replacement bolt cover?
Bennett Hart - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 10
За всё время: 9,220
