Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench.
After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side.
If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
Position the handlebars to your preferred height. Make sure not to pull cable and housing to tight. I could adversely effect shifting and braking performance.
Make sure you don't raise quill stem above minimum insert line.
Align the direction of the goose-neck (adjustable quill stem) with the front tire.
Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench.
Pop the bolt cover back on.
If calling a bicycle repair shop, refer to it as a adjustable quill stem (technical term) instead of goose-neck as mechanic may not know what you are talking about.
Еще один человек закончил это руководство.
