Введение
High tension caused by the strings can cause the wood of the fret board to bow. This bowing can become so extreme it becomes difficult or impossible to play on due to the string height. Thus, in this guide we will learn to loosen or tighten truss rod.
The truss rod can be replaced with the strings on or off. Because the Allen wrench is bulky, this guide will show how to adjust the truss rod with the strings removed. Once the strings are removed, the fretboard will begin to slightly bend upwards or downwards. This will determine how much adjusting will need to be done on the truss rod.
Выберете то, что вам нужно
Loosen all of the strings completely by turning each tuning peg counter clockwise. Continue until there is no tension in the strings
Remove each string by pulling it out of the string tree at the top and through the bridge at the bottom.
Thread the largest new string through the bridge hole farthest from the knobs. Hold it firmly in place.
On a taut string, measure one inch past the nut before using a pair of wire cutters to cut the string.
Take the end of the string and insert it into the hole in the middle of the string tree.
Use one hand to maintain tension in the string by grabbing the string and rotating the hand toward the fret board.
Rotate the tuning peg counterclockwise until the string is slightly taut, but not tight.
Check to ensure that the string is lined up with the proper notch in the nut.
Tighten the string until it is close to the proper tuning. Use an electronic tuner or an online tuner that uses your computer's microphone. (Google: Online Tuner)
Tune the thickest string to B, the second thickest string E, the next thickest to A, the next string to D, and the last string to G.
Because the strings will change pitch as the guitar body deforms due to increased tension, repeat step 12 after each string is tuned individually.
Remove the strings from the bass according to the string installation guide.
Remove each of the screws with the Philips #1 screwdriver.
Remove the plate covering the truss rod by sliding it off.
Locate the truss rod hex nut.
If your fret board is bowing upward towards the strings, loosen the truss rod by turn by turning the hex wrench a quarter to half turn counter-clockwise.
If your fret board is bowing down away from the strings, tighten the truss rod by turning the hex wrench a quarter to half a turn clockwise.
You've successfully adjusted the truss rod!
2 человек успешно провели ремонт по этому руководству.
