Adjusting the front bonnet
Выберете то, что вам нужно
  1. Adjusting the front bonnet, Locate the closing mechanism on the bonnet: шаг 1, изображение 1 из 1
    • Open the bonnet from the inside of the car (use the lever in the glove-box) and raise the bonnet completely open.
    • The 13mm screw used to adjust the closing mechanism of the bonnet. This is the one that probably needs adjustment
    • Screws which secure the mechanism to the bonnet
    • Spring which raises the bonnet slightly so that it can be further opened by hand
  2. Adjusting the front bonnet, Adjust closing mechanism using the screw: шаг 2, изображение 1 из 1
    • Use the 13mm Wrench to screw/unscrew the bonnet closing mechanism so that it gets adjusted. Usually it needs unscrewing a little so that it reaches the closing mechanism on the car.
    • The missing black paint on the screw indicates how much this bonnet closing mechanism needed adjustment
    • After adjusting, if unscrewing was needed and the closing mechanism screw shows unpainted parts it would be wise to spray-paint the area to protect from corrosion/rust in the future.
Заключение
After adjustment the front bonnet should fully close easily when lowering.
3 участников успешно повторили данное руководство.
Dan Mihai Ile
Участник с: 10/16/12
186 Репутация
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 12
За последние 30 дней: 35
За всё время: 4,508
