Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Assemble the required tools, including the Afridev tool and crescent wrenches.
Perform a water test on the pump, by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
Loosen the bolt on front of the face plate with the Afridev tool.
Remove the plate from the pump by lifting it straight up.
Insert the T-handle into the top cylinder of the exposed pump rod.
Loosen the 2 bolts on either side of the head to remove the handle from the pump rod.
While one person lifts up on the T-handle, remove the bolt and connection pieces.
