Введение
The barrel is the orange piece into which you insert the darts.
Запчасти
Никакие детали не требуются.
  1. Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together. Remove grey slider from the main body of the blaster. Remove grey slider from the main body of the blaster.
    • Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
    • Remove grey slider from the main body of the blaster.
  2. Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together. Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together. Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
    • Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed. Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed. Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
    • Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
  5. Remove the trigger, lifting from the bottom and pulling it out from under the metal pin. Remove the trigger, lifting from the bottom and pulling it out from under the metal pin. Remove the trigger, lifting from the bottom and pulling it out from under the metal pin.
    • Remove the trigger, lifting from the bottom and pulling it out from under the metal pin.
  6. Lift the barrel, pulling it out from under the black trigger catch Lift the barrel, pulling it out from under the black trigger catch Lift the barrel, pulling it out from under the black trigger catch
    • Lift the barrel, pulling it out from under the black trigger catch
Заключение
Joshua Taylor
Участник с: 22.09.2014
101 Репутация
1 Guide authored
Команда
USF Tampa, Team 3-1, Brown Fall 2014 Member of USF Tampa, Team 3-1, Brown Fall 2014
USFT-BROWN-F14S3G1
3 членов
Автор 5 руководств
Один комментарий
I don't remember this blaster's shell as being held closed by solvent weld or catches - why is the "iFixit" pry-tool necessary?
Arasin Staubly - Ответить
Просмотр статистики:
За 24 часа: 1
За 7 дней: 1
За 30 дней: 5
За всё время: 148
