Air Jordan 1 Crease and Scuff Removal
Выберете то, что вам нужно
  1. Air Jordan 1 Crease and Scuff Removal, Air Jordan 1 Crease and Scuff Removal: шаг 1, изображение 1 из 1
    • Unlace sneakers.
  2. Air Jordan 1 Crease and Scuff Removal: шаг 2, изображение 1 из 1
    • Stuff toe-box with paper towels until leather is stuffed to capacity.
  3. Air Jordan 1 Crease and Scuff Removal: шаг 3, изображение 1 из 1
    • Dampen a small towel.
    • Place damp towel across toe-box.
  4. Air Jordan 1 Crease and Scuff Removal: шаг 4, изображение 1 из 1
    • Using a flat iron, iron over the damp towel to remove toe-box creases.
  5. Air Jordan 1 Crease and Scuff Removal: шаг 5, изображение 1 из 1
    • Keep the towl on after ironing them to reduce odd cracks.
    • For best results, keep toe-box stuffed with paper towels until you're ready to wear.
  6. Air Jordan 1 Crease and Scuff Removal: шаг 6, изображение 1 из 1
    • Select Angelus Leather Paint that matches the original color of your shoes.
    • Using a small paint brush, paint over scuffs and scratches with their original color in thin, even coats.
    • Allow 20 minutes in between coats for paint to fully dry.
  7. Air Jordan 1 Crease and Scuff Removal: шаг 7, изображение 1 из 1
    • Re-lace sneakers.
Заключение
Once you've completed these steps, your shoes will be ready for wear.
22 участников успешно повторили данное руководство.
Mohammad Abdellatif
Участник с: 02/22/18
751 Репутация
1 руководство автора
Команда
University of Memphis, Team S4-G7, Baddour Spring 2018 Участник University of Memphis, Team S4-G7, Baddour Spring 2018
UM-BADDOUR-S18S4G7
2 членов
Автор 5 руководств
6 Комментариев
This is the best repair guide in the world.
Mohammad Abdellatif - Ответить
why and how because i have the all jordan but the only jordan that have a crease is the jordan 12
Azariea Ray - Ответить
Would this technique work on fearless zoom irridecent ? I know when I have had just a drop of water on then it looks oily almost like there is a fine coat of some sort on them
Brad May - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 15
За последние 7 дней: 74
За последние 30 дней: 421
За всё время: 90,998
