Введение
The battery gives the device enough power to save the settings when the device is unplugged. The battery is a circular object that is located underneath the logic board.
Запчасти
Детали не указаны.
Using a metal spudger, gently pry the cover off the bottom of the device.
To detach the small clips from the connectors, place the flat end of the plastic spudger underneath the clip and gently lever it away from the center of the device.
To detach the large clip from its connector, place the flat end of the spudger on the clip and lever it upward out of the connector.
Using two fingers, pinch the power supply wire and gently lift it upward. Move it away from the metal plate.
Next, unscrew the four 3.3mm T8 Torx screws and remove the metal plate.
Remove the T8 Torx screwdriver head and replace it with the 60 mm extension; then, add the T9 Torx head.
Loosen, but do not remove the two screws at the bottom of the 1.2-inch wide gap in the middle of the internal structure.
Using only your fingers, gently compress the internal structure and pull evenly upward to remove it from the white case.
Eight 10.25 mm T8 Torx screws secure the heat sink to the logic board. Unscrew all eight screws.
Remove the heat sinks from the logic board.
Wedge the corner of the plastic spudger under one of the silver antenna clips. Gently lever the tip of the spudger away from the logic board to detach the antenna clip.
Repeat this for all six clips.
To release the logic board, unscrew four 5.5 mm T8 Torx screws from the internal structure.
Remove the logic board from the internal structure.
Wedge the flat end of the plastic spudger between the battery and its casing.
To pop the battery out, firmly lever the spudger upwards.
3 участников успешно повторили данное руководство.
Комментариев: 5
im assuming the small battery gives some sort of power to make the airport function correctly
I’ve opened quite a lot of broken A1521 and always checked the battery. None of them worked with a new battery or due to the “reset”
Sorry…
Hi, my AE doesn’t flash the ethernet leds when I connect it to the power supply and it isn’t visible neither over wifi nor ethernet but the principal led changes from green to amber and finally flashes amber repeatedly. ¿some hint to fix it?. Thanks in advance.
does the small circular battery give the logic board any power cause I am having problems with a rapidly flashing amber light I just replaced power supply
