Введение
The oil required for cooling and lubrication of the compressor parts needs to be regularly checked. Dirty oil leads to performance loss and even damage.
The system takes about 0.2 liter (6.5 oz) of compressor oil.
Выберете то, что вам нужно
Using the 5mm hex key, unscrew the drainage plug.
With the plug removed, let the reservoir drain until no more oil comes out.
Screw the drainage plug back on.
Add the new oil through the filler hole.
Make sure the oil level on the indicator is between the lines.
2 участников успешно повторили данное руководство.
