Akai MPK25 Volume Knob / Pitch Bender Replacement
Выберете то, что вам нужно
  1. Akai MPK25 Volume Knob / Pitch Bender Replacement, Face Plate: шаг 1, изображение 1 из 1
    • Remove all the selector knob covers by pulling them off.
  2. Akai MPK25 Volume Knob / Pitch Bender Replacement: шаг 2, изображение 1 из 1
    • Using needle nose pliers, remove the washers from the four corner selector knobs.
  3. Akai MPK25 Volume Knob / Pitch Bender Replacement: шаг 3, изображение 1 из 1
    • Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
  4. Akai MPK25 Volume Knob / Pitch Bender Replacement: шаг 4, изображение 1 из 3 Akai MPK25 Volume Knob / Pitch Bender Replacement: шаг 4, изображение 2 из 3 Akai MPK25 Volume Knob / Pitch Bender Replacement: шаг 4, изображение 3 из 3
    • Carefully flip the device to the front making sure you secure the face plate and the chassis together.
    • Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides.
  5. Akai MPK25 Volume Knob / Pitch Bender Replacement: шаг 5, изображение 1 из 3 Akai MPK25 Volume Knob / Pitch Bender Replacement: шаг 5, изображение 2 из 3 Akai MPK25 Volume Knob / Pitch Bender Replacement: шаг 5, изображение 3 из 3
    • Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
    • Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged.
  6. Akai MPK25 Volume Knob / Pitch Bender Replacement, Volume Knob / Pitch Bender: шаг 6, изображение 1 из 1
    • Rotate the device 180 degrees, so that the motherboard is closest to you.
    • Take caution to not damage the ribbon cable connecting the face plate to the chassis.
    • Remove the ribbon cable connecting the knobs to the mother board by gently wiggling and pulling it away from the motherboard.
  7. Akai MPK25 Volume Knob / Pitch Bender Replacement: шаг 7, изображение 1 из 2 Akai MPK25 Volume Knob / Pitch Bender Replacement: шаг 7, изображение 2 из 2
    • Using a Phillips #2 screwdriver, remove the four 9.5 mm silver screws holding the knobs to the face plate.
Заключение
5 участников успешно повторили данное руководство.
Serbinder Singh
Участник с: 01/30/13
81 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 20-6, Maness Winter 2013 Участник Cal Poly, Team 20-6, Maness Winter 2013
CPSU-MANESS-W13S20G6
5 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 11
За всё время: 2,524
