Введение
If your Akko MOD 007 v2 has a switch not working correctly, you will need to replace the keyboard switch to restore its functionality. These keyboard switches wear down over time, rendering them inoperable as they no longer register. Before replacing the switch, inspect the keyboard to confirm that it is the switch and not the PCB malfunctioning.
In this guide, you'll learn how to replace the keyboard switch through on your Akko MOD 007 v2. It has two features that make it simple. The keyboard is hot-swappable, which allows you to replace the switch without soldering. In addition, when buying a replacement keyboard switch, the Akko MOD 007 v2 is compatible with both PCB-mounted (5-pin) and, Plate-mounted (3-pin) switches.
Replacing more than one switch can be reproduced by repeating these instructions.
Выберете то, что вам нужно
Flip the keyboard over so the backside is facing up.
Remove the three longer 20.2 mm screws using the T5 Torx screwdriver.
Remove the three 8 mm screws using the T5 Torx screwdriver.
Orientate the new switch to align the pins to the board's sockets.
Push the switch down into the sockets.
Test the switch by opening a keyboard tester website, like 'keyboardtester.com,' and press the key to see if it activates.
